I am trying to use the time series chart which is in beta. When I am using the table option, the data is displayed.
That data looks very sparse with a value every 3 hours or so and also only on one day of the 14 you have chosen.
In the Time series panel options, if you change the style to be points instead of lines - do you see the points show up?
If you choose line as the style, then you can test changing the “Connect null values” option to be always.
If neither of those options work, what do you see in the Query inspector on the Data tab?
