When using templating in the alert messages, it seems the alert use the first values where the last ones are in fact the most interesting. How to use the most recent values?
Steps to reproduce:
- create a query generating a table with some values (timeseries)
- generate an alert with an error message containing a ${variable} based on on of the column of the table
- the message will be filled by the oldest value for this column, instead of the most recent one
The value in the printed error message will be “0.9” instead of “0.06”.
Grafana Open Source 7.5.2
- What are you trying to achieve?
Print the last value
- How are you trying to achieve it?
Using templating
- What happened?
The oldest value is shown
Print the most recent value
No errors.
- Did you follow any online instructions? If so, what is the URL?
