Tabs On Mobile for viewing the dashboard using Browser Link
Developed Mutiple panles for sales and orders pednign with 13 tabs consists of 78 working database query panles consits graphs mostly daiily , weekly , monthly, quarterly, yearly saels orders panles. when we use on Mobile i think after 13.2 we have tabs prev. we have rows . rows are visible onthe Mobile However tabwise are not appearing is there any Grafana app to install onthe mobile to see ? please clarify or did I miss anything to view properly.
is there anyway we lin browser to app which can show exactly the way it shows on the Desktop
Grafana dashboards can be viewed on mobile, but no setting makes the mobile view identical to desktop. Mobile uses a responsive layout, so dashboards with many tabs and panels can look different.
You can try →
Mobile browser: open the dashboard in landscape mode, or use the Desktop site option to see the desktop layout.
Tab layout: check the Layout setting on each tab (Auto vs Custom) and see whether it changes how the panels display.
Grafana mobile app: it’s documented for Grafana Cloud accounts, so it likely won’t apply if you’re self-hosted.
For 13 tabs and 78 panels, a separate mobile-friendly dashboard with only the key panels is usually easier to use on a phone. You can link to the full dashboard from it.
Are you using Grafana OSS/self-hosted or Grafana Cloud, and which exact version are you running? That will help us work out why the tabs aren’t showing.
thanks for your prompt response testing grafana OSS 13,2,2 . already tried desktop layout. Sr. Managers are not that much comfortable as of Now so Checking. so as per documentaion app works for cloud only. we are evaluating multiple options Power Bi/ grafana/ etc… thanks again for your reply with all details
13 tabs is a lot even on a non mobile device from a ux/UI design principle
What about 2 panel dashboard with one for filter the rest for the visualization
Are you showing different kinds of graphics?
Most of your panels look like the same graphs at different periods, so you can cut the dashboard down a lot:
Period variable → create a variable such as $period (daily, weekly, monthly, quarterly, yearly) and use it in your queries. One panel can often replace several. This works when the period only changes the time grouping, e.g. via $__interval or a variable in your SQL GROUP BY.
Filter variables → add variables like region, product or sales team so the viewer picks what to see instead of scrolling through every panel.
Short mobile dashboard → keep a separate dashboard with only the 5 to 8 key panels and link to the full dashboard from it.
