Hey,
Got problems with “Format as => Table” (Splunk plugin) when using two or more queries.
The columns from the second query (B) are missing.
However when using “Format as => Time series” then everything works as expected.
Am I missing some way to make a column a primary key?
Hi! Seems, that’s a bug. What you mean under “primary key”?
Yes, looks like a bug to me too.
I just didn’t know the lingo to use for the question, what I meant was: Am I missing some way to select a column from the two results that will be used to join rows?
… Þröstur
