System Feedback
Issue Category:
System Feedback
Issue:
There is no system feedback as why the page is blank.
Recommendations:
System feedback should always be provided so user can know
Can you provide some more information about the problem.
Is this an issue with Grafana? It looks like it is embedded in another application?
Yes it is embedded with other application…
But we are unable to show the no data is present information.
Regards
Priyanka Priyadarshini sahoo
You mean that there should be some text that says there are no snapshots? Like we have for dashboards (“No dashboards found”):
Yes, like dashboard for snapshot also same messge should be come.
Regards
Priyanka
