Syslog-ng > Loki: how to set up separate tenants
Hi all,
I have the following pipeline working: Syslog-ng logs > Grafana-Agents (behind an F5) > Loki Cluster and can query the logs in Grafana successfully.
  • We filter the syslog data in syslog-ng to create log lines based on source device/application. How do I set up multi-tenants for Loki to store each syslog source in a separate index (ie Cisco ASA, palo alto, ect)?
  • Is this even possible since the Grafana-agent is only listening on port 1514?
Current Agent config
server:
log_level: info
metrics:
global:
scrape_interval: 1m
wal_directory: ‘/var/lib/grafana-agent’
logs:
configs:
  • name: default
    positions:
    filename: /tmp/positions.yaml
    scrape_configs:
    • job_name: syslog_ng
      syslog:
      listen_address: 0.0.0.0:1514
      labels:
      job: syslog_ng
      clients:
    • url: http://(hostname):3100/loki/api/v1/push
Thanks in advance!
Christine
