Synology Firewall blocks for CSV query
Hello everyone,
I am brand new to the Grafana community.
I have a Grafana OSS instance running on my Synology in Container Manager. I have installed the CSV plug-in. Now I want to retrieve weather data from the address (https://data.geo.admin.ch/ch.meteoschweiz.ogd-smn/abo/ogd-smn_abo_t_now.csv). However, the Synology firewall is blocking it. When I disable the firewall completely, it works fine. I’ve tried playing around with ports and IPs, but without success.
Does anyone have experience with which ports need to be opened for the data.geo.admin query to work? I don’t want to disable the firewall completely.
Many thanks for your help.
welcome to forum @giodev781
Check this out
I would recommend you use infinity plugin and see if this issue goes away?
