Hi, Can i add Sybase Database as a data source in grafana?
Hello alaaka! You can find the list of supported datasources here. Official and community data sources plugins are listed here. Unfortunately, Sybase Database is not part of supported datasources, neither there is a datasource plugin for it. I have also checked github, if someone has created Sybase plugin that is not listed on our website, but I couldn’t find any. Maybe you can try, if you can connect Sybase to Grafana trough any other datasource plugin? For example Microsoft SQL Server (MSSQL)? I am honestly not sure, if it is going to work, but I think it is definitely worth a try!
Thank you so much
