I have a dashboard with different panels for different metrics. I want that a subset of these panels are available for the public without login.
At the moment I have 2 different organisations “OrgXYZ” and “public” each with a copy of the same dashboard with some panels removed on the dashboard for the “public”. In general this is what I want, but I have to maintain 2 dashboards. If I add an annotation for “OrgXYZ” or change something else in the dashboard, I have to do the same on the dashboard for the organisation “publuc”.
Is there a way to have only one dashboard which can be accessed with and without login? If accessed without login only a subset of panels should be visible and it should be read only (viewer role).
