I have installed the status panel and I’m able to select it. However, it is not showing the data I expect.
I saw the information "Currently the plugin was tested with influxDB and Graphite."
Is it supported with Zabbix database? If not, do you know when it will be?
thanks!!
It should work with Zabbix. It should work with any data source that returns time series data. I haven’t tested with Zabbix but I have tested with Prometheus for example.
