I am currently building out a dashboard which uses multiple types of exporters, node_exporter, micrometer for microservices, mariadb exporters and Blackbox exporter.
In using the Blackbox exporter I have the ability to create a status panel which indicates the status of the system UP/DOWN using
probe_success{instance=~"$target"}
Is there similar functionality within the metrics for the microservices actuator and the mariadb exporter?
I have tried passing in the microservice/db address as the target but this did not work.
Any help would be appreciated.
