Status panel for prometheus instances - HOW?
I’m having a prometheus metrics which can only take the values 0 or 1 and I would need to create a status panel showing a green tile for each instance having the value 1 and, accordingly, a red tile for 0.
As an example see the following prometheus query:
How would I define a Grafana panel showing 1 red tile (for the instance “shell001.mo-staging00-nonprod.ams1.cloud”) and 8 green tiles, based on this prometheus metric called “check_salt_complete”?
E.g. using GitHub - Vonage/Grafana_Status_panel: A panel plugin for Grafana to monitor multiple parameters at once
hi @rasstef
This is very achievable with Grafana. But to give you the clearest guidance: what version of Grafana are you using?
you can use value mappings to map colors and text strings to specific values:
https://grafana.com/docs/grafana/v7.5/panels/field-options/standard-field-options/#value-mapping
