v9.3.2 -
In stat visualisation I’m trying to display the last value as text but use aggregated data for the graph. Data in my postgres database is raw, non-aggregated. I’m using this query to obtain the data for the graph, for displayed Value I’m using Calculate > Last *. However since the query aggregates the rows to some interval ($__interval) even the last row is aggregated. Is it possible to somehow display the graph aggregated but keep the Value really the last, non-aggregated row?
SELECT $__timeGroup(logdate, ‘$__interval’, NULL) as time,
AVG(value) as “Value”
FROM table
WHERE logdate >= now()::date AND logdate <= now()
GROUP BY time
ORDER BY time ASC
I tried getting the aggregated data and using UNION also select the last row explicitly as non-aggregated like this:
select $__timeGroup(logdate, ‘$__interval’, NULL) as time,
FROM table
GROUP BY time
ORDER BY time ASC
) UNION (
SELECT
extract(epoch from logdate),
value
FROM table
ORDER BY logdate DESC
LIMIT 1
What happened?
It totally destroyed the graph. -
That the graph would display the aggregated values + last one as non-aggregated and the Value would display just the last non-aggregated value. -
No errors.
- Did you follow any online instructions? If so, what is the URL?
