Good morning,
Is there a way to calculate a value (true/false) based on the following scenario, using data received by an SNMP walk on a network switch using Telegraf and an influxes backend.
Will the current copy process finish in time?
- There is 20TB of data to be transferred
- The transfer started on Sep 1, 2021
- It needs to be completed by Dec 1, 2021
- After x days, x data has been transferred and with the current transfer speed, it will make it or not
if ($currentTransferredData >= (20/80)*(Days since Aug 30))
$willMakeIt = true;
} else {
$willMakeIt = false;
