Hi community,
I’m experiencing an annoying issue with Grafana stat panels connected to Loki datasource. Every time the dashboard auto-refreshes, the panels briefly show “No data” for about half a second before displaying the correct value again. This creates a constant flickering effect that makes the dashboard look unprofessional.
Setup:
Datasource: Loki
Panel type: Stat
Time range: Last 2 days
Auto-refresh: Every 5 seconds
What’s happening:
Dashboard refreshes every 5 seconds
During refresh, stat panel briefly displays “No data”
Then the correct value (e.g., “16”) appears again
This repeats on every refresh cycle
What I need: A way to keep displaying the last known value during the refresh cycle instead of showing “No data”. The stat panel should maintain the previous value until new data arrives, rather than clearing and re-rendering on each refresh.
Is there a setting, transformation, or query configuration that can prevent this flickering behavior in stat panels with Loki datasource?
Thanks for any help!
