The easiest way would be to tag the stages. When querying the resulting metrics you can filter by the stage/s that are not in your warm-up.
Can you further elaborate on the reasons behind the behavior you need in the test? I understand you don’t even want k6 to measure the warm-up stages, is that correct? I’m asking in case it’s a feature we should consider, or there is another way to achieve that. We’d like to understand the reasoning behind it. Or tagging the metrics already works for you?
Thank you.
Tagging by stage helps - but the end-of-test summary does not include the tags, so they are only useful when looking deeper in the cloud results and/or Prometheus and the like.
Further – when using K6 cloud, the top graph and summary are not affected by tags. A special tag like “excludeFromSummary” whould help here.
Noam.
