Hi!
• Open Source | v9.0.1 (14e988bd22)
• Debian GNU/Linux 11 (bullseye) aarch64 -
I figured the easiest way to ask my question was to create a panel similar to what I am trying to achieve vs. what I currently have. So I faked it in Paint (Sorry if my copy pasted values trigger anyone’s OCD )
I would like to visualize movement data from my smarthome sensors. In order to program my thermostats in a sensible manner it would be beneficial to analyze movement patterns on heatmap providing hours of the day on the x-axis and days of the week on the y-axis. See figure 1.
The other panel shows what I am able to currently draw from my data.
figure 1 (desired panel)
figure 2
Figure 2 is close to what I am trying to get. Its a comparison of all movement detected in one room. However, deducting conclusions from this is not as intuitive as from the heatmap.
Thanks!
