12.3.1, Ubuntu 22.
- What are you trying to achieve?
Using an Elasticsearch data source and a Lucene query, I have a horizontal bar chart showing the top 5 doc counts of the string field “message.software.name.raw”. For each of those 5 bars, I want to break them down by the field “message.software.component.raw”. So then each bar will show the total records, but be composed of different-colored parts that describe how many of each of the top 5 components contribute to the length of the bar. 5 bars, 1 for each of the top five software, broken down into the top 5 parts describing software components.
- How are you trying to achieve it?
I have a Lucene query which gives me the numbers that I expect. Then:
Metric: Count
Group By: Terms - “message.software.name.raw” - Top 5, Order By Doc Count
Then By: Terms - “message.software.component.raw” - Top 5, Order By Doc Count
- What happened?
No matter how I configure the chart, I cannot get the behaviour I want. I end up with 10 bars on the graph, 5 that describe the top 5 software counts, then 5 that describe component. I can’t get them to stack. I’ve tried every variation of setting the “X Axis” setting and “Color by field” setting. Flipping “Stacking” between “Off” and “Normal” has no effect.
I’m hoping for the stacking I described at the start.
- Can you copy/paste the configuration(s) that you are having problems with?
N/A
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
N/A
- Did you follow any online instructions? If so, what is the URL?
I asked Grot AI but it says that there is not enough documentation it is trained on to provide a working answer.
