SSO in Grafana using Apache reverse proxy use custom login form
as per http://docs.grafana.org/tutorials/authproxy/#apache-basicauth I made the respective configuration in Apache httpd.conf file. But using this, Apache throws its default alert popup to enter credentials when i redirect to Grafana.
Instead of the dirty popup, i want to use my own custom login form. I used mod_auth_form like this:
Alias /secured/ ${SRVROOT}/htdocs/www/
<Directory "${SRVROOT}/htdocs/www/">
    AuthFormProvider file
    AuthType form
    AuthName realm
    Session On
    SessionCookieName session path=/
    require valid-user
    # This is the login page
    AuthFormLoginRequiredLocation /auth/login.html
    # This is the file containing users login data
    AuthUserFile ${SRVROOT}/htdocs/password/.htpasswd
</Directory>
# This is an 'open', unsecured, directory.
# place here your fance login html and css files.
Alias /auth/ ${SRVROOT}/htdocs/www-auth/
<Directory "${SRVROOT}/htdocs/www-auth/">
 Require all granted
 Session On
</Directory>
# Our login form should reference to this location
<Location /auth/dologin.html>
 SetHandler form-login-handler
 AuthFormLoginSuccessLocation /
 AuthType form
 AuthName realm
 Session On
</Location>
# Refer to /auth/logout to reset
<Location /auth/logout>
 SetHandler form-logout-handler
 AuthType form
 AuthName realm
 AuthFormLogoutLocation /auth/loggedout.html
 Session On
</Location>
But I am not able to redirect to Grafana by sending X-WEBAUTH-USER in headers
hi, have you solved it?
