Hi All,
I was wondering if there is a way to specify the provider inside the host parameter when connecting Grafana to an MSSQL database since you can specify multiple connection properties such as ApplicationIntent using the ‘;’ character to separate each property.
Something like an .udl file
Provider=SQLNCLI11.1;Persist Security Info=False;User ID=XXXX;Initial Catalog=Database1;Data Source=localhost;Initial File Name=“”;Server SPN=“”
Grafana version 9.0.1
Cheers and thanks for the help
