Specify custom parameters when creating annotation
Hi all,
I’m using Annotation Panel (from novalabs), -which is simple but very useful- and I sometimes need to generate non global annotations (ie. annotations linked to a particular resource ; ex events,server=db1 title=reboot,text=i have rebooted this server only).
Does anyone else has same needs ?
If yes, how do you do ?
thanks
thomas
If you don’t get an answer here then you could try opening an issue on the Annotation Panel plugin GitHub repo: https://github.com/novalabs/grafana-annotations-panel
Oh great, I haven’t see that this project was on githab.
I’ll post there, thanks.
