Hi all,
using Grafana 5.2.3 I am not able to get repeating Singlestats working.
I have a variable defined with folders, which I use in filecount-plugin (telegraf).
Displaying them individually is possible, but I have a lot of folders I want to display and it is too much work for generating a panel for each. So I tried using variable and “repeat” for each value of that variable.
Grafana now creates a panel for each folder, but I am not able to display the right value.
I tried selecting only values, where “directory ~= /^variableX/” - I don’t get a valid value. If I specify a directory in the directory tag it works. but not when I use the variable.
Any ideas?
regards,
andre
Your syntax is wrong, try:
directory =~ /^$variable$/
excuse, i made a typo here. the syntax is correct, i used grafana gui for chosing the values.
but nevertheless i
here is the code from query inspector:
“xhrStatus”: “complete”,
“request”: {
“method”: “GET”,
“url”: “http://xx.xxx.xxx.xxx:8086/query”,
“params”: {
“db”: “d3”,
“q”: “SELECT last(“count”) FROM “filecount” WHERE (“directory” =~ /^“X:\/ab\/defghijkl\/mnopqr\/stuvw\/xyz”$/) AND time >= now() - 1h GROUP BY time(30s) fill(null)”,
“epoch”: “ms”
“data”: null,
“precision”: “ms”
“response”: {
“results”: [
“statement_id”: 0
I don’t like a double quotes in your regexp:
Do you have double quotes saved in the directory tag values?
You may need advanced variable formatting for your use case: http://docs.grafana.org/reference/templating/#advanced-formatting-options
Tried it with changed variables and it works. I don’t need to use any quotes in variable definition!
thx a lot!
regards,
andre
