I have a sensor connected and is sending info about humidity and temperature. Sometimes the sensor has an error and returns hum=0 and temp=0.
Is it possible to filter this data when this happens?
Thank’s for your help
Eduard
Eduard
Depends on your data source and its query language features, some have filter features i the query language
was able to create new dashboard add dashboard list panel and add a tags filter and save fine.
http://play.grafana.org/dashboard/db/new-dashboard-copy?orgId=1&panelId=2&fullscreen&edit
