Hello Grafana Community,
I recently upgraded my Grafana instance from version 8.5.x to 10.1.8, and since the upgrade, I’ve noticed a significant increase in the read IOPS for the Aurora Reader instance, which is causing a noticeable increase in costs.
Here are some details about my setup:
Grafana Version: 10.1.8 (upgraded from 8.5.x)
Database: Aurora MySQL
Deployment: Kubernetes, using the Aurora Reader instance to fetch data
Issue: A sharp increase in read IOPS since upgrading. The IOPS seem higher even for queries that previously didn’t cause this much load.
I have reviewed the following:
- Queries executed by Grafana (such as fetching data from
data_source
andalert_notification_state
tables) - Dashboard settings and refresh intervals
- The performance of the Aurora instance before and after the upgrade
Has anyone else experienced a similar issue after upgrading from Grafana 8.5.x to 10.1.8? If so, what steps did you take to reduce the read IOPS? Are there any specific settings or optimizations I might have missed?
Any advice or guidance would be greatly appreciated!
Thanks in advance!
