I’m a newbie to grafana.
I have a mysql 8.0 datasource where I store some result in a table.
One of the datatypes is list of floats store as a json-type (always array, not object).
Eg:
[0.017488631429, 0.26068300203, 0.07274529954, 0.01087933394, 0.11306773303, 0.22424935174, 0.032254569974, 0.01134010573, 0.19860789179, 0.14142807333, 1.5267597024, 1.3590681816, 1.4012729169, 1.904265782, 1.9979217332, 1.7610441844, 1.9176101905, 2.418887416, 2.3316332515, 2.1566200344]
Is it possible to show/transform these values into a histogram?
After some reading I found the answer myself.
mysql> set @json= '[0.017488631429, 0.26068300203, 0.07274529954, 0.01087933394, 0.11306773303, 0.22424935174, 0.032254569974, 0.01134010573, 0.19860789179, 0.14142807333, 1.5267597024, 1.3590681816, 1.4012729169, 1.904265782, 1.9979217332, 1.7610441844, 1.9176101905, 2.418887416, 2.3316332515, 2.1566200344]';
Query OK, 0 rows affected (0.00 sec)
mysql> SELECT *
-> FROM
-> JSON_TABLE(
-> @json,
-> COLUMNS(
-> Value float PATH "$"
-> ) data;
| Value |
| 0.0174886 |
| 0.260683 |
| 0.0727453 |
| 0.0108793 |
| 0.113068 |
| 0.224249 |
| 0.0322546 |
| 0.0113401 |
| 0.198608 |
| 0.141428 |
| 1.52676 |
| 1.35907 |
| 1.40127 |
| 1.90427 |
| 1.99792 |
| 1.76104 |
| 1.91761 |
| 2.41889 |
| 2.33163 |
| 2.15662 |
20 rows in set (0.00 sec)
