Hi
I have a measurement in InfluxDB with multiple fieldssets. Because i have to add the different fields together and multiply with a constant. And i also want to display the different fields seperatly. And i read that you can’t add different measurements.
So this is in a nutshell why i didn’t make different measurements for all the fields.
But now i want to display the 3 seperate fieldset through a variable and i can’t put it in a tagset. So is it possible to show/hide a query through a variable without making use of the tagset?
I hope i make some sense .
Thanks at advance!
Kind regards,
Ward
