Show PDF in a Dashboard and integrate into a Playlist
I am trying to create a playlist with grafana where I will rotate dashboards. Here everything is OK and i do it.
I need to insert a PDF page. Is it possible to insert a PDF in a panel?
It is fine whether the PDF is integrated each time I need to change it, or whether the PDF is taken via URL.
Important that the playlist once started, shows the PDF page after the dashboards.
Suggestions?
@madmaxnew Check out the Business Media panel
