Show name in legend
I am trying to add tags to the Dataframe in the OSISoft Plugin but something is not working properly.
This is the legend for the OSISoft plugin:
This is the legend for the InfluxDB plugin:
You can see that in red the name property in the Dataframe is shown in the Legend for the InfluxDB plugin.
I am using the toDataframe function to generate the dataframe.
    "data": [
            "name": "AST-M01-102-01HCR|Valor Atual",
            "refId": "A",
            "meta": {
                "path": "\\\\SAURIOPIAF02\\M01\\M01_102\\M01_102_CH4\\AST-M01-102-01HCR|Valor Atual",
                "pathSeparator": "\\"
            "fields": [
                    "name": "Time",
                    "type": "time",
                    "config": {},
                    "values": [
                        1676640986192
                    "name": "Value",
                    "type": "number",
                    "config": {},
                    "values": [
                       111
                    "labels": {
                        "element": "AST-M01-102-01HCR",
                        "name": "Valor Atual",
                        "type": "Double"
            "length": 1
You can see that the name property is set ok, but is not shown in the Legend for the OSISoft plugin.
Any ideas what I might be doing wrong?
Thank you,
Paulo Vitor
Managed to find the solution. Thank you.
For the benefit of others, do you want to share your solution?
Adding the tag name to the value Field and not to the Dataframe. GridProtectionAlliance/osisoftpi-grafana at feature/v4.0.0 (github.com)
