V7.3.5 -
I’m using Graphana for some IoT devices and want to use it for maintenance reasons.
So I’d like to show all Devices which aren’t sending data anymore for a longer period of time (2 days) -
I’m trying to get the last entry to the InfluxDB and filter it with time.
This is my query:
SELECT data FROM
(SELECT last("data_123") AS data FROM "autogen"."database" GROUP BY "device")
WHERE time < now()-2d GROUP BY "device"
What happened?
The nested query doesn’t work. I get entries in the table from devices which sent data within the two days. The shown entry is the last one before the time filter (e.g 2 days and 5 mins) -
I expected that the inner query would only get the last updates from each device. With the second query I would filter out every device which sent an update whithin the two days
I would be glad, if somebody can help me. Thank you.
