Since I haven’t found any other threads or issues providing this pattern, I want to share an Alloy loki.process
config that I devised to capture and format logs from Pino, a widely used NodeJS logging library. Of particular interest will be the way in which the numeric level
values are translated into human readable “structured metadata” values using a Sprig template.
loki.process "pino_json" {
stage.json {
expressions = {
level = "",
pid = "",
err = "",
hostname = "",
message = "msg",
stage.timestamp {
source = "time"
format = "UnixMs"
// Translate Pino numeric log levels
stage.template {
source = "level"
template = "{{ get (dict "+
"10 \"trace\" "+
"20 \"debug\" "+
"30 \"info\" "+
"40 \"warn\" "+
"50 \"error\" "+
"60 \"fatal\") .level }}"
// Level and Unfrequently searched fields belong here
stage.structured_metadata {
values = {
level = "",
pid = "",
hostname = "",
// Build the labels set - must be low-cardinality!
stage.labels {
values = {
err = "",
// The log body will just be the message
stage.output {
source = "message"
forward_to = [loki.write.pino_logs.receiver]
Tested with Loki 3.4.2
