Sharing of panel images has problems
We are using Grafana Cloud. And we would like to share a rendered snapshot of a panel.
The most simple thing would be to have a direct link as this:
Unfortunately that does not seem to be working (for us). The URL just never loads.
Is that a limitation of the Cloud product?
The next best thing would be to create a snapshot.
This feels a little too manual.
What I found is the shapshot API that could maybe be used to automate this?
Is the API the right path forward here?
This note feels a little discouraging:
When creating a snapshot using the API, you have to provide the full dashboard payload including the snapshot data.
The full dashboard payload is no problem - but what is meant by “snapshot data”?
Hi @tcurdt!
The feature to share a panel by direct link should not be a limitation in Grafana Cloud. I tested this myself just now and saw some odd behavior though. The direct link rendered image URL for my first test dashboard took a whopping 58 seconds to load, while my second test dashboard in another region took about 7 seconds. This delay might be related to an ongoing incident we have, as my first test is in the us-prod-central-0 region while the second test is not. I will continue to investigate this with my team to determine why the response time is so long.
For alternative sharing options, you can choose to use the Snapshot option as you mentioned, using the Grafana UI. I found a related issue regarding the discouraging sentence you found in our docs that clarifies the snapshot API is intended to be used by the Grafana UI only.
The new Public Dashboards feature might be another alternative approach, though I recommend reviewing the current limitations beforehand. This is an opt-in feature, so if you would like to test this out for your account please open a support ticket from your account portal to request it!
I just checked. It seems to working again.
That said - only somewhat.
I have redacted quite a bit as I don’t know how much I may share,
but I guess it’s enough to see the problem:
How it should look like:
How it does look like:
Thanks for your help!
