Set publishing dashboard using config file
I can publish a dashboard to public using UI.
But how can I publish via config file like dashboard.yml or json file or even API?
My demand is when I start hosting the system, the public dashboard is available and I do not need to publish manually.
Thanks!
Hello
This might help
@yosiasz thanks for your reply.
I can set up the GFN that automatically creates data sources from DB and builds the dashboard. The dashboard is available right after I start the GFN. It is OK!
However, I would like to publish the dashboard so that clients can view the dashboard with a fixed link. Currently, I can’t see any document instructing how to make the dashboard public at the starting time.
Could you help me, thanks?
