v8.3.3 (30bb7a93ca) under Debian 11 and Ubuntu 20.04 LTS -
Have two sessions in parallel to servers with same host name and different port numbers -
Two tabs in Firefox, rest see above -
What happened?
Tab 1: login to the first targetcommunity.grafana.com, and select a panel.
Tab 2: log into the second targetlocalhost:3001. and select a panel.
Tab 1: click for example on the panel search, that brings me to the login dialog -
That I can have both sessions in parallel
Background
We have a production and a test system.
In home office I access both systems through layers of firewalls and bastion hosts via
ssh -L 3000:community.grafana.com <ssh_alias_of_production_system>
ssh -L 3001:community.grafana.com <ssh_alias_of_test_system>
This way I’ve both Grafana servers easily accessibly via two localhost ports.
But the session management is apparently not able to handle that.
