11.4.0 -
creating dashboard in grafana thru prometheus values retrieved from IBM WebSphere Application PMI metrics
Got the PMI metrics successfully from IBM WAS and able to see the metrics values in prometheus. -
What happened?
High session count values displayed in Prometheus always, For example) The was_session_live_sessions values from IBM WAS is 3, but it shows as 7 in prometheus
The was_session_live_sessions should match according to the PMI metrics from IBM WAS. -
no errors, but only the wrong session values not accordance with the real user log in session counts during a specific time when logged into the application.
no
