Hi All,
I had to burn a new SD since the previous got corrupted so I had to re-install Grafana and InfluxDB.
While InfluxDB installation was successful, Grafana installed without errors but when I typed “systemctl status grafana-service” it resulted “Active: fail (Result: exit-code)…” and it doens’t open.
I checked the grafana log at “/var/log/grafana” and I found this line:
msg=“Server shutdown” logger=server reason=“Service init failed: Migration failed err: database disk image is malformed”
Why so?
It’s a Raspberry Pi 3 with Buster.
Thank you, regards.
Roberto
