grafana 10.0.2/ alertmanager v0.24
- What are you trying to achieve?
Send alerts with reply-to address in addition to SMTP_FROM
- How are you trying to achieve it?
I do not believe this is supported - based on grepping the repo and the lack of documentation
I just wanted to confirm this and ask if anyone can suggest a workaround or whether this is something that could conceivably be a feature request.
Our scenario is that we need a validated from: address but don’t want alert responses going to this wider group. SMTP does differentiate between these uses - see RFC
