Scientific Notation of numbers
Grafana 8.4.0, InfluxDB Cloud
I would like to present the numbers in this graph in a scientific notation. Is this possible? If yes how?
Thanks
Roland
Configure Unit correctly:
Yes, you will loose unit W/m², but numbers will be in the scientific notation as you need. Unfortunately, you can’t have everything and you have to choose between scientific notation or unit. I would use axe label for unit.
