Grafana 9.0.3 and Ubuntu Linux -
I am trying to stream data from Grafana Backend Plugin. -
I have implemented the Backend plugin as per the recommended mechanism -
What happened?
I am not able to get hold of the queries in the RunStreamRequest() method. Whereas I could get hold of the queries in the QueryData() method with the *backend.QueryDataRequest reference and execute them, the subsequent streaming call to RunStreamRequest() method does not expose the queries through *backend.RunStreamRequest. Please help me and tell me how do I get hold of the queries so that I can fetch them and execute them at my end. -
I was expecting that the *backend.RunStreamRequest would give me the list of queries that I can loop through and execute to fetch data from my backend system. -
NA -
NA -
NA
