Route localhost website through grafana
I am running the latest v7.1.5 Grafana on a local computer.
I also run a https video stream with python webserver using flask on the same local computer.
Both are in different docker containers but connected with an internal docker network (10.10.0.XX).
If I create a Text or Ajax panel, I can view the stream in grafana (https://192.168.0.10:3000) using the normal ip address of the host in the panel settings (https://192.168.0.10:5555/stream).
But that means anyone can link direct and view this directly without grafana and I can’t block the 5555 port with a firewall.
Is there a way to route the website through grafana 10.10.0.XX network and then be able to set a firewall to block direct access to the python webserver.
This means that the end user has to login into Grafana to view the video stream in a panel ? I use this with a lot of information displayed in other panels in the dashboard from an influxDB database.
