Is there a way to rotate a map in the Worldmap plugin? Or is there a different plugin that can rotate a map?
By “rotating” I mean to set the North direction to a different direction than straight bottom to top. An example: I would like to show a long stretch on the map and to do that I would like to use all available width of the screen, so I need to rotate the map accordingly.
Any help or hint is more than appreciated,
Thank you.
C.
