Hello.
Cant assign a role to the user. I
m using auth.proxy with keycloak
Grafana - v8.3.6
Keycloak - v16.1.0
What did I miss?
In the logs I see the following information:
proxy logs:
> debug|keycloak-gatekeeper/handlers.go:88|incoming authorization request from client address|{access_type: , auth_url: <url>protocol/openid-connect/auth?client_id=grafana&redirect_uri=https%3A%2F%2Fgrafana1.net%2Foauth%2Fcallback&response_type=code&scope=openid+email+profile&state=<key>, client_ip: <ip>}|
> info|keycloak-gatekeeper/handlers.go:179|issuing access token for user|{email: user@example.com, expires: 2022-04-19T16:21:41Z, duration: 4m59.258862845s}|
> debug|keycloak-gatekeeper/session.go:51|found the user identity|{id: <id>, name: user, email: user@example.com, roles: grafana_admin, groups: }|
> debug|keycloak-gatekeeper/middleware.go:337|access permitted to resource|{access: permitted, email: user@example.com, expires: 299.144459781, resource: /*}|
grafana logs:
> lvl=dbug msg="Trying to log user in" logger=auth.proxy username=user@example.com ignoreCache=false
> lvl=dbug msg="Getting user ID via auth cache" logger=auth.proxy cacheKey=auth-proxy-sync-ttl:asfasw2345235dsfsd8998808ca7871e0
> lvl=dbug msg="Failed getting user ID via auth cache" logger=auth.proxy error="cache item not found"
> lvl=dbug msg="Syncing organization roles" logger=login.ext_user id=2 extOrgRoles=map[]
> lvl=dbug msg="Not syncing organization roles since external user doesn't have any" logger=login.ext_user
> lvl=dbug msg="Got user ID, getting full user info" logger=auth.proxy userID=2
> lvl=dbug msg="Successfully got user info" logger=auth.proxy userID=2 username=user@example.com
> lvl=dbug msg="Updating last user_seen_at" logger=context userId=2 orgId=1 uname=user@example.com user_id=2
> lvl=dbug msg="Successfully got user ID via auth cache" logger=auth.proxy id=2
> lvl=dbug msg="avatar.fetch(fetch new avatar)" logger=avatar url="https://secure.gravatar.com/avatar/b85af2188bffede41fe15268ea567e13?d=retro&r=pg&size=200"
> lvl=warn msg="Request Origin is not authorized" logger=live origin=https://grafana1.net host=127.0.0.1:3000 appUrl=http://localhost:3000/ allowedOrigins=
> lvl=info msg="Request Completed" logger=context userId=2 orgId=1 uname=user@example.com method=GET path=/api/live/ws status=403 remote_addr=<ip> time_ms=1 size=10 referer=
My config:
[analytics]
check_for_updates = true
[auth]
disable_login_form = true
disable_signout_menu = true
[auth.anonymous]
enabled = false
[auth.basic]
enabled = false
[auth.proxy]
auto_sign_up = true
enabled= true
header_name= X-Auth-Email
header_property= email
headers= Name:X-Auth-Username Role:X-Auth-Roles
role_attribute_path= contains(roles[*], 'grafana_admin') && 'Admin' || contains(roles[*], 'grafana_editor') && 'Editor' || 'Viewer'
[grafana_net]
url = https://grafana.net
[log]
level = debug
[paths]
data = /var/lib/grafana/
logs = /var/log/grafana
plugins = /var/lib/grafana/plugins
provisioning = /etc/grafana/provisioning
security:
admin_user: admin@example.com
extraContainers: |
- name: oauth2-proxy
image: quay.io/keycloak/keycloak-gatekeeper:6.0.1
args:
- -listen=:4181
- -upstream-url=http://127.0.0.1:3000
- -discovery-url=<realm url>
- -enable-refresh-tokens=true
- -encryption-key=<key>
- -client-id=grafana
- -enable-authorization-header=false
- -client-secret=<secret>
- -resources=uri=/*|roles=grafana_admin
- -resources=uri=/metrics|white-listed=true
- -resources=uri=/api/datasoruces|white-listed=true
- -resources=uri=/api/dashboards|white-listed=true
ports:
- name: proxy-web
containerPort: 4181
