I am having an issue with making my panels a bit more human readable.
The issue is that I have two databases. One contains the data that I display + IDs for each of the metrics, while the other contains the IDs and the Human readable names.
By using only the IDs, I get this:
If these tables were on the same database, I would just use a join or something similar. But the two tables (and databases) are on different servers altogether.
This is the query I use:
SELECT UNIX_TIMESTAMP(statusDate) as time_sec, REPLACE(statusValue,' %','') as value, nodeID as metric FROM platformStatus_201711 WHERE statusName = "cpu" AND platform_id IN ($platform) AND $__timeFilter(statusDate) ORDER BY statusDate ASC
Any ideas on how to trick it so that it will display the Names instead of the IDs?
Thanks a bunch in advance!
Cheers!
