We have a weird issue with promtail (2.1.0) with kubernetes 1.18 when a pod is restarted. At the start of promtail, all target are “True”. In the attachment, you can see that the target becomes “FALSE”, it is a pod I explicitly restarted and if I jump inside the pod, I can see that the pod uuid doesn’t match the one which is supposed to be up (you can compare it with the screenshot).
root@promtail-ql879:/var/log/pods# ls
*************_engine-5b89b9bc56-mzkhv_e0cae657-d0c5-4415-830e-ab4de445ca20
Here is the configuration we use
client:
backoff_config:
max_period: 5s
max_retries: 0
min_period: 100ms
batchsize: 102400
batchwait: 1s
external_labels: {}
tenant_id: *******
timeout: 10s
positions:
filename: /run/promtail/positions.yaml
server:
http_listen_port: 3101
log_level: info
target_config:
sync_period: 10s
scrape_configs:
- job_name: default
kubernetes_sd_configs:
- role: pod
relabel_configs:
- action: replace
source_labels:
- __meta_kubernetes_namespace
target_label: namespace
- action: keep
regex: (.*)
source_labels:
- __meta_kubernetes_pod_container_name
- action: replace
regex: (.*)
replacement: $1
source_labels:
target_label: container
- replacement: /var/log/pods/*$1/*.log
separator: /
source_labels:
- __meta_kubernetes_pod_uid
target_label: __path__
- action: replace
source_labels:
- __meta_kubernetes_pod_node_name
target_label: node
Thanks for your help!
