EU Germany - prod-eu-west-2 - prod-eu-west-2 -
I would like to have my instance being restarted -
I would like to ask you to restart it, as i do not have the option to do so. -
What happened?
I am missing servers in my dashboard. -
There is missing one of my servers (pulled the data from a Prometheus server). -
No -
No errors -
No
if your aws instance opensuse leap 15.5 you can use this command to restart the server
sudo systemctl restart prometheus
if you are using window then you can go to services and then restate the grafana service and form prometheus you can close and then start again
don’t know which os you are using..
Hello ,
I don’t know how to login to that service, I mean I opened a cloud version of grafana.
I don’t have a local server running, but when I am in my grafana environment there is no option to reboot the instance.
How do I proceed?
Thank you in advance!
Grafana Cloud doesn’t have a restart option, and you shouldn’t need to restart it. You are doing something wrong when you think that you need to restart it.
