Is there any possibility to select resource name instead of resource id for displaying graph in gnocchi grafana integration.
Remembering resource id is difficult for end-user. It would be good if user can select resource name
Thanks,
Akshay
Thanks,
Akshay
Try to reach out to the gnocchi data source authors / maintainers. The core Grafana team has not used that data source so it’s hard for us to know what it can do in this case.
Thanks for instant reply. Much appreciated. I am using graph panel for the displaying graph.
It does not really matter what panel you use, if you want to change the name of the series you need to change your query somehow. So it needs to happen in the gnocchi data source or in your gnocci query.
