Require multiple variable formats to be applied to a query
    OSS Grafana v10.1.2 , Mac OS Ventura 13.4
    This was regarding setting multiple values for a variable in grafana. We have integrated grafana dashboard with Restful api. As mentioned here https://grafana.com/docs/grafana/latest/dashboards/variables/variable-syntax/, we have added sub_c=${sub_c:csv} to a query path to get comma separated values, but we also need to add encoding for this, something like sub_c=${sub_c:percentencode}. How can I set both the values in grafana ?
    I tried a lot of things like sub_c=${sub_c:csv}&sub_c=${sub_c:percentencode}
  • What happened?
    It takes only one value either csv or percentencode
    I need both variable format options.
    /api/xyz?sub_c=${sub_c:percentencode}&sub_c=${sub_c:csv}
    Yes, when I use the above query, its not able to encode the variable with special characters. For text like β€˜Tax & Treat(Tn)’ it gives me following error - β€˜Unknown parameter Treat(Tn) found’
    Yes, I refered Variable syntax | Grafana documentation
