Request to Customize Time Picker Presets (Restrict >30 Days)
Hi Grafana Support Team,
I am using Grafana v12.0.2 and embedding dashboards in my product.
I want to customize the time picker presets so that time ranges above 30 days (e.g., 90 days, 1 year, 2 years) are removed from the default dropdown, while keeping the search bar and standard user experience intact. Also i want to remove Copy/Paste, Change time setting, Time range zoomout.
Currently, I see that:
  • Using custom quick ranges removes the search bar.
  • There is no supported option in the UI to remove specific presets.
Could you please advise:
  1. Is there any supported method (UI or config) to remove specific default time presets above 30 days , Copy/Paste, Change time setting and Time range Zoom out without losing the search bar?
  2. If not, are there any upcoming features or planned enhancements in Grafana roadmap to support this?
  3. Are there any undocumented or enterprise-only settings to achieve this behavior?
