Repeat by variable option is not working properly on Flowcharting panel
Repeat Options is enabled with Repeat by variable in the Flowcharting panel. Still Flow charting shows animations only in one panel but not on all the other panels.
Event/Animation Mapping rule is configured properly. Based on the variable values it creates multiple panel but animation effect is not working all the panels.
Any idea to make animations work on all the repeated panels.
Thanks,
Debasish
I encounter the same issue (panels are not repeating, while a variable has been selected to be used for the panels that should repeat).
How is repeat suppose to work?
