The render api (
http://<USER>:<PASS>@<HOST>:<PORT>/render/dashboard/db/test
) seems to produce a 504 error when including a parity report panel in the dashboard(https://grafana.com/grafana/plugins/zuburqan-parity-report-panel).
This functionality works with the same dashboard when the panel has been removed. With the panel added, the identical api call subsequently fails with a 504.
Is this normal?
Many thanks
