Remove empty values from table - Google Sheets Edition
Hi everyone,
While I found some responses regarding removing empty values from Graphite queries, I was not able to find the equivalent for Google Sheets. I query a table that appears only if a certain value is triggered and therefore, I am currently stuck with a lot of empty table values. Any way to prevent this? I can’t do it on Grafana’s side and I’m not finding a way to do it with the Google Sheets plugin.
Thanks for the help,
-Laurence Olivier Marion-Ouellet
Did you get any solution to this? I am also facing the issue
Thanks,
Nshree
